RCA Color Trak 2000 Television
Username: Barbiee
Hi i just was given one of these and when i turned it on and did an autosearch it is stuck on V1. How do i get it off of that?
Username: Plymouth
Post Number: 16522
Welcome to eCoustics Barbiee!
This old colortrack was a very good TV but the tuner experiment some problem, the reason why you get only the V1 which is Video 1 is that the tuner get nothing!
You can use a old VCR to get your channel or a Digital/analogic TSC converter like the one to get the new digital channels then kook it in the V!, V2 or V3 according to your model!
This is a sample:
http://www.ezdigitaltv.com/RCA_DTA800B1.html
Need to Register?
Forgot Password?
Enable HTML code in message
