Backing Up Video Tapes To DVD - Using Video Stabilizer
Username: Limerick_boy
UK
Hi
I have some old video tapes i would like to back up on to dvd. But they are copy protected. What Video Stabilizer would be best to use?
Thanks
Username: Ericboflovsky
Hi Greg,
There are two most popular video stabilizers - sima ct-200 and dimax grex . The first one is not supported anymore cuz Hollywood sued that company and you can find only used devices on ebay or elsewhere, the second one - dimax grex (which i own) you can find here http://www.xdimax.com/grex/grex.html.
Username: Oldlady
Hi Greg, you have a grey dimax? having trouble with getting mine to work. can you help?
Need to Register?
Forgot Password?
Enable HTML code in message
