LG HT305SU Region Unlock
Username: Bart1x
Hi Does anyone have the code for unlocking this DVD player cheers Jez
Username: Drdoom2010
You can use the "LG5000 hack" to get it region free.
The procedure is same as in the HT503TH.
"1) Download
http://www.digitalfaq.com/downloads/dvdhackarchive/lg5000.zip
2) Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
3) Insert the disk to your player, disk will be ejected shortly and menu will appear.
4) Select 0 for all regions and press ENTER and then PAUSE on remote to confirm.
5) You have multiregion theater.
6) Have Fun!"
It's tested, do it with confidence.
Username: Bartona
Hi,
I tried that proceduce and it didn't work for me. I get a message that says "Disc Error" and the dvd pops out. No Menu appear on the tv screen. Any ideas?
Thanks
Al
Need to Register?
Forgot Password?
Enable HTML code in message
