Viewsat Ultra Lite Weather Forecaster Down
Username: Jtuff
Post Number: 11
Is the Viewsat Ultra Lite Weather Forecaster down?
Username: Chevrolet
Post Number: 344
Viewsat WEATHER FORECASTES:
Viewsat Ultra WF - DN -up
Viewsat Ultralite WF - DN -up
Viewsat 9000HD WF - DN -up
Viewsat MAX HD WF - DN -up
UP on 119/110 W
Down on 118/61W
Username: Jtuff
Post Number: 12
Thanks mine just came back up, was down last night and this morning
Username: Johnscarro
need help with vs/wf,do I have to subscribe thanks.
ultra
Username: Virusinjector
Toronto, On Canada
Post Number: 307
No,
https://spreadsheets.google.com/lv?key=tY5yYarz54zUYizXbNs5rJg&toomany=true#gid= 41
Username: Toothpic
Post Number: 250
Username: Yovanibot
Post Number: 33
mine is down..Can someone please tell me what file its running..ultra Thanks
Diamond Member
Username: Nydas
Post Number: 20304
Hmm: A new tactic. Let's see.
If you drink a lot of beer, and then are drunk, some kind soul will drive you home, or the Police will put you in overnight in the cooler. I think the latter alternative is better for you because that is more like home to you.
Username: Yovanibot
Post Number: 34
nydas, thanks for coming on..i thought i had a virus, but is just pain of a zzz. Can you please help me, where to find the information for the viewsat ultra..thanks.
Diamond Member
Username: Nydas
Post Number: 20306
Geo: I take it that you have WF and were up before.
Username: Yovanibot
Post Number: 35
I was, running great, with the 100909u file, took me a while to get it running almost a week.. But it went down today, I see that it is up, but not on my end. I trying to re install the file. system clean and starting from scratch. Its connecting to the internet and updating files but still scrambled.. thanks
Diamond Member
Username: Nydas
Post Number: 20309
1. Shut down computer and receiver. and any other devices/computers attacked to router.
2. Disconnect all cables to the router.
3. Wait full 1 minute.
4. connect the WF cable to router and tuirn on.
5. Wait full 1 minute.
6. Turn on computer if you want to
7. Try and see channels or scan again. and view.
Username: Yovanibot
Post Number: 36
ok, thanks..I will try that..
Diamond Member
Username: Nydas
Post Number: 20311
Geo: It is getting late for me. I will look at your response tomorrow morning.
Username: Yovanibot
Post Number: 37
no problem, thanks for your help, did that and just waiting
Username: Yovanibot
Post Number: 38
I tried it, left it on all nite. The setting on the wf are correct. I am using the 100909u file. just no picture.
Username: Superjazzyjames
Post Number: 899
Weather forecaster down? Look out the window!
Username: Chevrolet
Post Number: 368
Geo.........see if this C/P will help
How to Factory Reset Viewsat Ultra
By Carrie Catalano, eHow Contributor
updated: December 10, 2010
The Viewsat Ultra is a satellite TV receiver. If the receiver is not receiving a signal, freezing up or just not working correctly, you can reset it to factory settings. Resetting the unit to factory settings is the first step in troubleshooting the Viewsat Ultra. Once factory settings are restored, all of your personal preferences and stored information, such as television show reminders, will be deleted and cannot be restored.
.Difficulty: Moderately Easy
Instructions.Things You'll Need:
Viewsat Ultra remote control
1
Turn on the Viewsat Ultra receiver and your television.
2
Press the "Menu" button on your remote control. This will take you to the Main Menu. The menu button is located above the "Channel Up" button.
3
Press the "Channel Up" and "Channel Down" buttons to scroll through the options on the Main Menu. Stop when "User Settings" is highlighted. Press the "OK" button to select this option. The "OK" button is the small, circular button located between the "Channel Up," "Channel Down," "Volume Up" and "Volume Down" buttons. If you have set a PIN code, you will be asked to enter it, followed by the "OK" button.
4
Highlight and select "Factory Default" from the "User Settings" menu.
5
Select "Yes" when asked whether you wish to proceed. The factory reset process can take several minutes to complete. Do not attempt to use the receiver until the reset is complete.
Username: Yovanibot
Post Number: 39
yeah..did that too.. started from scratch..virgin box..reinstall all files and them back again to 09u file. Is the system down or am I down for good..
Post Number: 902
Look out your windows people! °o°
Username: Chevrolet
Post Number: 369
Geo........check this Link
Username: Yovanibot
Post Number: 40
dont know guys, looks like the window is calling me...this happened last week and I was able to get it running. I tried to redo all steps but get no image. I even did a system clean, and tried the older files. Is it up? or is just mine. have the 09u file for ultra
Diamond Member
Username: Nydas
Post Number: 20319
Geo: I do not have any more suggestions for you.
I think reviewing all you did or perhaps writing down each step as you d o it and comparing with instructions might help you to review your work and find any mistakes you might have made.
Username: Yovanibot
Post Number: 41
thanks.. I am again trying from scratch..again..like groundhogs day..but oh well..got it to work last time, maybe I will get lucky again.thanks time and for your help..
