Sony KP-61HS30 Looks 3D, Color Problem Please Help
Username: Mec4040
Hello,
I first want to say that this forum is great has lots of good info. I tried searching thru some old posts to see if anyone had similar problem but could not find anything.
The problem...I had this Sony KP-61HS30 for about 7 years. It was working great as of 12am last night. I shut the tv and when I got up this morning and turned it on....it looked 3D.
Meaning...the whole image on the tv, looks like it is in 3D. The colors look like red, blue and green. Also the image bows into the center just a little. I thought maybe it was the cable signal (yes, I know dumb) so I put a dvd in and same problem.
Does anyone know what might be the cause of this...or maybe what I can do to check and see what is wrong. Meaning is there something I can look at inside the tv or use a multi-meter.
Thanks in advance,
Mike
Username: Moledigger
Mike sorry about your tv I wish I could help but I have the same problem so I need help to. Hope somone can help. Thanks
Username: Plymouth
Post Number: 15437
Welcome to eCoustics Merrill!
Look like the 2 convergence IC's
Read these threads about your problem:
http://www.fixya.com/support/p229091-sony_kp_61hs30_tv
Need to Register?
Forgot Password?
Enable HTML code in message
