Need new stb SA8300HD. want to save recorded material to new box.
Username: Lernerfilm
Just got a Logitech Revue w/ Google TV. Logitech says it won't work with the Scientific Atlanta 8300HD provided by Comcast that I have
that was manufactured in 2005. They say I need one built after 2008. Comcast will give me the new one, but wife doesn't want to lose all the recorded material on DVR. Some way to save shows and put them on the new box when i get it?
Username: Ieee488
Post Number: 559
You can buy a DVD recorder with a hard drive and use it like a VCR. Magnavox sells two models. Connect the DVD recorder per the instructions on page 12 of the the STB's manual.
Username: Samijubal
Post Number: 4332
Save to an external hard drive if the box has an active usb connection.
Need to Register?
Forgot Password?
Enable HTML code in message
