Nova
Username: Frobi
Post Number: 508
I get 110 fine but no pictures on 118. I get guide, setting looks good but screen blank with usual massage of service not available. Files are good since I get 110. LNB freq is 10750 with 80 percent Q ans S. Have the right LNB for 118. Any ideas?
Username: Mrskullz1
New York
Post Number: 1668
it may be that particular channel (s) your trying to view are not open on the server. That message comes on when you are not connected to the suns sever. That can either mean that channel is currently not available or your receiver is not online (but in your case you said 110 works fine). Are all channel on 118 giving you this issue?
Username: Frobi
Post Number: 509
Thanks Mr. Skullz. Yes, none are working on 118, but fine on 110. I see guide but no picture on any 118
Username: Plymouth
Post Number: 14372
neil
Try a new scan on 118W!
It is need to assigned the channels to server!
Username: Frobi
Post Number: 510
I did that Plymouth several times. I can scan all channels on 118, shows guide on each channel but no picture. 110 works fine. On same LNB, CNX (now down) worked great on 118.
Username: Plymouth
Post Number: 14375
Edit!
Username: Frobi
Post Number: 511
Thanks Plymouth. I have problems with NOVA.
Username: Plymouth
Post Number: 14376
Sorry Neil I'm blinded with another thread!
You can try a factory default then rescan your satellites!
Try a hard reboot on back panel switch before!
