Nfusion prgramming Help Please
Username: Tasmanian_satellite
Post Number: 95
i need someone to guide me through nfusion menu to program 110,119 and whatever else i need to do to the receiver so i can receive dn. thanks
Username: Nydas
Post Number: 19207
Tasmanian:
You could look at http://www.nfusionforum.com or
http://www.dummychat.com or
wait for Plymouth to answer you.
Username: Plymouth
Post Number: 14329
tasmanian satellite
Are you pointed on Bev?
If yes! Use this utility to reaimed your dish: http://www.dishpointer.com/
I menu>installation>antenna setting: choose 110 then put those settings:
110W
LNB Type: standard
Lo Freq: 11250
22 hz: off
DiseqC 1.0: Port 2
DiseqC 1.1: disable
Multi-Dish Switch: Disable
Lock Tp: 12355 H 20000
Motor settings: Off
LNB Power: On
119W
LNB Type: standard
Lo Freq: 11250
22 hz: off
DiseqC 1.0: Port 1
DiseqC 1.1: disable
Lock Tp: 12457 H 20000
Motor settings: Off
LNB Power: On
Those setting are for a Diseq switch then you must have 2 Lnb's to get both satellites!
The files is available at nfusionforum.com or dummychat like Nydas listed above!
Post Number: 97
thank you's very much for the help and knowledge..i will try that today and hope all goes well...tahnks again
Username: Plymouth
Post Number: 14338
tasmanian satellite
Note that nfusionforum is down today but dummychat still up!
Post Number: 98
do i get file numbers from dummychat also
Username: Plymouth
Post Number: 14340
Yes! But you must be registred!
