Silver Member Username: LizwakefieldPost Number: 123 Registered: Dec-06 | HI I CANT GET IT TO WORK IT SAYS SUNS DISCONNECTED WHAT SHOULD I DO ???? PLS HELP ME I RESCANED ALL THE CHANELS AND NOTHING ((((((( |
Platinum Member Username: PlymouthCanada Post Number: 14303 Registered: Jan-08 | Hi Liz! You must load the latest file, doing a factory default then rescan all your satellites! Do a hard reboot on back panel switch then wait on a available channel! |
Silver Member Username: LizwakefieldPost Number: 124 Registered: Dec-06 | than youuu i did that its working fine but now when i tried to scan the satelites 110/119 it says that both are catching 119??? so my 110 is working right now and 119 is not? do you knwo how that can be that both are catc hing 119 ??? pls elt me know thank you ur the best |
Gold Member Username: KirankumarNO Bashing Post Number: 3206 Registered: Oct-07 | Liz, your antenna settings are wrong, you need to assign port numbers to 119 and 110 |
Platinum Member Username: NydasPost Number: 19157 Registered: Jun-06 | Try input port 1 for 119 and Port 2 for 110 |
Silver Member Username: LizwakefieldPost Number: 125 Registered: Dec-06 | thats waht i did i have 119 in 1 and 110 in 4 u are talking about the switch right? i am not sure waht port is? |
Platinum Member Username: NydasPost Number: 19168 Registered: Jun-06 | Your general thinking is right. The 110 might be at 2 or 3 and not at 4 Perhaps you should post info on your dishes, LNBs and switches. |
Gold Member Username: KirankumarNO Bashing Post Number: 3210 Registered: Oct-07 | you are right...a switch normally has 4 ports...1,2,3 and 4 and like Nydas says, try port 2 or 3 for 110 and you should be good to go. you need to make these changes on your receiver in the antenna settings |
Silver Member Username: Pu_da_mundaPost Number: 180 Registered: Feb-07 | Can someone can tell me that Boot: R3X 1.30 Software Ver : 1.54.2 IPVR 0.77 is the new file for Solaris??? I am not getting any pictures for any channel |
Platinum Member Username: NydasPost Number: 19206 Registered: Jun-06 | You will easily get your info at these two sites and a change of files if necessary |
Platinum Member Username: PlymouthCanada Post Number: 14328 Registered: Jan-08 | Sidhu Read this thread: https://www.ecoustics.com/electronics/forum/home-video/638688.html |
