Viewsat Max HD
Username: Robbie12
Post Number: 103
I am reading on other sites that the factory bin is relesed for VS Max (PFTAHDMSW_100426HM.zip) and they are working now on the proper file for the WF to work with the MAx. which means that we are very close to bring that box to life!
anyone can confirm?
Username: Plymouth
Post Number: 13822
Robert
The MaxHD file is available at ftacp:
http://www.ftacp.com/forums/showthread.php?1419-Viewsat-MaxHD-Factory-Weather
You must login to download the files!
Username: Robbie12
Post Number: 104
you mean that the max hd is working with the weather forecaster ?
i already downloaded the file.
Username: Plymouth
Post Number: 13824
Robert
Yes the file is out for the WF!
Username: Robbie12
Post Number: 105
why it is so quiet, it is supposed to be a big news!
Username: Plymouth
Post Number: 13826
I know since this morning but forget to post here!
Sorry!
Username: Plymouth
Post Number: 13827
Robert
Do you have the WF hub??
Username: Robbie12
Post Number: 106
yes i have the weather foecaster, why?
Username: Plymouth
Post Number: 13828
Robert
Just to know!
Reply if it work!
Thanks!
Username: Robbie12
Post Number: 107
i will try it and will let you know for sure
Username: Torpainter
Post Number: 65
thanks but there is no bin file out for this unit
Username: Robbie12
Post Number: 108
hey Tor, what is this file then?
Username: Nydas
Post Number: 18870
The following was posted at satfix.net on the 27th April, 2010
'Viewsat MaxHD Factory - Weather Forecaster
Attached is the factory bin for the MaxHD receiver. This file gives working use of the Weather Forecaster.
This will work with your MaxHD and the Weather Forecaster for your Weather needs.
Instructions are the same for this model as the Ultra & Ultra Lite... only difference will be the file to flash to receiver.
Regarding the factory bin, they have posted the following quite a while ago.
"VIEWSAT-VSMAXHD-V0114.zip
this is the official factory file
I do not own this receiver and I have no idea whether or not you can get good weather forecasts from it.
Post Number: 72
The bin file was supposed to be released by the weekend but its been delayed till early next week
Username: Robbie12
Post Number: 110
Max Hd is not working with the weather forecaster and the PFTAHDMSW_100426HM.zip
I think we still need another file, let us hope it is coming out soon.
Post Number: 92
I told you there is no bin file yet!! The only thing you will get with the factory file is the weather
Username: Plymouth
Post Number: 13840
Yes
The file was reported!
Post Number: 93
the file was reported to be what?
Post Number: 94
It does get the weather
Username: Robbie12
Post Number: 111
same thing with 9000HD,
so max hd and 9000 hd will be up soon with the weather forecaster!
