BIG problem with the Mitsubishi 55inch HDTV model ws-55908
Username: Sadie78
There is a loud buzzing sound and no picture. the words in the corner that indicate which in input you are in is double laid with one in red and below it in green. I unplugged the tv for 10 minutes and it was back to normal then went right back to buzzing and no picture. it was fine before we went out about an hour and a half ago. Any idea whats going on and how to fix this??
Need to Register?
Forgot Password?
Enable HTML code in message
