Silver Member Username: TulipePost Number: 158 Registered: Jun-09 | i did reading but very confusing . i m waiting for my sonysat4000 but need the steps to get it working . which files to use for the box and the showmex2 . thanxxxxxxx |
Bronze Member Username: Crispy_fryPost Number: 18 Registered: Aug-09 | c/p How to upload Showme X2 using Wiznet Program on the Sonysat4000 & SpaceStar 500/700 Make sure ShowmeX2 Dongle is connected to the Sonysat 4000 or Spacesar 500s or 700s and plug a network cable from your dongle to your router and Power Supply,toggle Switch ON. 1) Run WIZNET Program (Window XP Base) 2) Reboot the STB and/or the X2 Dongle, wait about 7 seconds and Click - Search- 3) You see Ver 1.3 and the IPS, with the Server IP and Port 90. 4) Normally end users uses the Router, DHCP is selected automatically.. 5) You can upload the new Showme X2 firmware using UPLOAD icon and processing COMPLETE will be done. Hit Serial Tab change SPEED from 9600 to (115200) Continue for next Step WAIT UNTIL PROGRESS BAR SHOW COMPLETE. Now Load SilverSufer Beta file to Sonysat 4000 or Spacestar 500/700 using the Null Modem Data Transfer Cable and the Sonysat Loader V2 for these Receivers Go to MENU Configuration Embedded CAS CAS Mode: IKS Press OK and Exit Place on CH 122 Hit EXIT and Power OFF sonysat from the back of the STB or merely unplug the power cord if there is no Rear Switch. Power On Back go to a channel 122 wait for picture Silversurfer EKE V2.1 ShowMeX2-V2.2 Beta Readme wiznet |
Bronze Member Username: ChaffPost Number: 83 Registered: Jan-10 | ccccccccccccc , let the forum know how it works out for you... Plymouth has posted that the older models are not supported. |
Platinum Member Username: PlymouthCanada Post Number: 13246 Registered: Jan-08 | Chaff aka LK 4000 is not a old model! Try again! |
Bronze Member Username: ChaffPost Number: 85 Registered: Jan-10 | It's tiresome .... you posted older models don't work.. Tell the forum which models you are talking about then. |
Platinum Member Username: PlymouthCanada Post Number: 13249 Registered: Jan-08 | Chaff aka LK Support is for 4000, 5000 and 5500! DGR 3100 is old model! http://sony-sat.net/products.htm Are you satisfy! Now you look stupid! |
Bronze Member Username: ChaffPost Number: 87 Registered: Jan-10 | Plymouth you pick an obscure model made for the south american market and you say I'm stupid.... https://www.ecoustics.com/electronics/forum/home-video/117151.html the old models are supported |
Platinum Member Username: PlymouthCanada Post Number: 13253 Registered: Jan-08 | You look more stupid than before with your 2005 link! How can you be so stupid? |
Bronze Member Username: ChaffPost Number: 88 Registered: Jan-10 | I was trying to show you [using your favorite ecoustics site] that the spacestar from 2005 is still supported w / IKS ...They don't have any earlier models , so you are wrong as usual. |
