Sonysat4000 showme x2 adapter voltage????????????????
Username: Tulipe
Post Number: 163
i got my sonysat4000 and show me x2 with it . no power adapter i read that sonysat 4000 need power adapter for x2. i wanna get one but im confused in the back of showme x2 it says DC + 5V . BUT WHEN I WAS LOOKING OVER SITE THAT SELL THEM IT says :Input : AC 100 - 240 VAC (50~60Hz)
Output : 9V DC 1A. im confused which voltage x2 realy need .?????? thanx
Username: Plymouth
Post Number: 13409
Tulipe
If 5 volts DC is showed on X2, this is 5 volts require!
Username: Tulipe
Post Number: 164
ply thanx becuz some pple say 9v some says 5.5 and other say 6v. but the back says 5v
Username: Plymouth
Post Number: 13412
Tulipe
6 volts can do but it is the max!
Username: Tulipe
Post Number: 165
i bought power adapter 5v 500ma it wsorked. but frm time to time i loose the picture and i have to uplag and plag again the power so it will work . is that how it is with sonysat each time i got to go and turn off from the back and on ????????????
