RTN (Racetrack Network) 95.0W Setup
Username: Xbucklawx
Hi all, first post here, just wondering if it is possible to have this up and running on an old viewsat box. Was searching (googling) and came across a thread that was quite long, but in the middle had some info from november of 2009 that this was working but didn't give specifics on how to achieve this. OleMacDonald and Plymouth were discussing. Thanks in advance, xbucklawx
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 692
meathead.........I don't think anyone here has the the right
keys for Racetrack TV Network at Galaxy 3C at 95.0°W
for now if you want to see the ponies run point your dish to
AMC 5 at 79.0°W TP freq. 12177 Pol. H SR 20,500
Username: Plymouth
ModeratorCanada
Post Number: 12208
meathead
Here is the good keys:
N C801 00 E134079992603E3B ;RTN (95.0W)
N C801 01 AF96389F9259304A ;RTN (95.0W)
Username: Xbucklawx
thanks for the keys plymouth, the only thing confusing me now is the C801...... i am on nagra (in the code) but cannot find the galaxy just a bunch of other ones, do i use unknown instead? and again the c801 is confusing......good signal and good quality as well, channels are scanned but are saying no audio no video.......thanks in advance....
Username: Plymouth
ModeratorCanada
Post Number: 12209
meathead
Here is the instruction for create a provider and keys lines:
1. Enter Main Menu -> Options -> Autoroll OFF
2. Go to Installation -> Code -> Nagra. Inside this menu press F1 on remote to create new provider. Write RTN or new provider name, then press Sat Button to Save then in numbers on the left, insert 09 01 00 or the new providr ID number. Save.
3. You should see 8 pairs of FF. With cursor go to first pair and insert 00, then select last pair and press FAV on remote to create the new key.
4. On new key, go to first pair of FF and insert 01. then select last pair and press FAV to create new key.
5. Go to first pair and insert 20, then to last pair and FAV to create final key.
6. Go to first pair and insert 21. At this point you should see this on your screen:
provider ID RTN 09 01 00 .
00: E1 34 07 99 92 60 3E 3B
01: AF 96 38 9F 92 59 30 4A
Username: Xbucklawx
thanks plymouth, i'll go try this and report back.....
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 90
hey plymouth can i put theses on the vs ultra, and also do i need to be hook to the dish or can i put them in first then do hook up...had some issue putting in to reciever before xmas, can't get the keys at the end,,,will try again.
Username: Plymouth
ModeratorCanada
Post Number: 12213
laughlin
You must create the Provider which is RTN C801 then add keys lines 00, 01 then put those keys on those lines, on FF you put 00
00: E1 34 07 99 92 60 3E 3B 00 00 00 00...
01: AF 96 38 9F 92 59 30 4A 00 00 00 00...
You must have a june bin file, last working with Dn
Post Number: 92
where can i get the june file plymouth
Username: Chumley
Post Number: 796
I don't think you need the latest bin , HERE Plymouth had the RTN before the june bin was released. also keep in mind plymouth stated he used C901 as provider id and in this thread he uses C801. GOOD LUCK
Username: Plymouth
ModeratorCanada
Post Number: 12219
laughlin
You can find this bin at dsstester. com
Chumley
C801 or 901 will not make any difference
So if you are not able to answer, please stay out of this thread!
We don't need your idiot comments!
Username: Chumley
Post Number: 797
Plymouth , I don't see where you gave an answer, only a c/p of the keys and a c/p of some instructions that say the viewsat keys are labeled 00 and 01, 20 and 21. }
Username: Nydas
Post Number: 17318
Chumley: The discussion was and is between meathead and Plymouth.
YOU ARE JUST BUTTING IN UNNECESSARILY.
PLEASE STAY OFF THIS THREAD.
Username: Plymouth
ModeratorCanada
Post Number: 12238
laughlin
Read this post, it will help you for RTN:
https://www.ecoustics.com/electronics/forum/home-video/572775.html
Username: Chumley
Post Number: 804
Looks like Plymouth's sending laughlin on wild goose chase
ALL that thread says is plymouth can get it and won't give details.
Username: Nydas
Post Number: 17333
Username: Chumley
Post Number: 805
Its an open discussion ..now carry on with your c / p duties and stfu.
Username: Nydas
Post Number: 17335
Read this post
Username: Chumley
Post Number: 806
quote:
Plymouth
Posted on Tuesday, March 03, 2009 - 10:58 am: Edit Post
I confirm, all RTN, OTB 1-2. RDTHN and HRTV wide open on Viewsat Ultra with these keys.
But not easy to create the provider for it.
After many try I know how do it now.
and yet he doesn't help
https://www.ecoustics.com/electronics/forum/home-video/609323.html
https://www.ecoustics.com/electronics/forum/home-video/608866.html
Username: Nydas
Post Number: 17337
CHUMLEY:
YOU ARE STILL INTERFEREING UNNECESSARILY.
Username: Plymouth
ModeratorCanada
Post Number: 12245
Cumley
You ask questions and answer yourself!
Your link prooved that I was able to get it and the other link give Juan who explained how do it!
What you want more?
Username: Nydas
Post Number: 17342
Plymouth: Important that you look at the new information on Nfusion, I have posted in another thread.
Username: Chumley
Post Number: 807
Playmouth ..Juan also posted this ,I don't why, but It dosen't works .
They try everythings,.
Playmouth , the link proves you were able to get RTN ,but you can't give any instructions.
Its obvious you c/p juans instructions(which is also a c/p) to other threads,
Are viewsat key lines entered like this 10,11,20,21 look like coolsot key lines
10 FF FF FF FF FF FF FF FF
11 FF FF FF FF FF FF FF FF
20 FF FF FF FF FF FF FF FF
21 FF FF FF FF FF FF FF FF
OR THIS
08 FF FF FF FF FF FF FF FF
09 FF FF FF FF FF FF FF FF
88 FF FF FF FF FF FF FF FF
89 FF FF FF FF FF FF FF FF
Nalin...You are seasoned enough to know not to highjack a thread.
Please start your own thread if you want to discuss another matter besides RTN and plymouth's inability to help someone enter keys to their viewsat.
Username: Plymouth
ModeratorCanada
Post Number: 12246
laughlin
You must create the Provider which is RTN then C801 then add keys lines 00, 01 then put those keys on those lines, on FF you put 00
You must create another with C901 then add keys lines 00, 01 then put those keys on those lines, on FF you put 00
Use Juan instruction to add the provider and keys:
here is how.
Viewsat - How To Add A New Provider ID Al VS extreme usando el bin DBPSW-090417X, pueden crearlo en otro VS si usan el bin de esas fechas que tienen amazonas, ya con provider 7311,
y le agregan el Provider ID 73 06 00 para telefonica, aqui esta como
This is a C & P.
Como agregar un nuevo provider
Algunas veces esto puede ser util agregar manualmente un nuevo provider ID en el code menu para habilitar adicional llaves de encripcion que no estan incluidas, para poder ver adicional contenido encripted
por ejemplo RTN on Galaxy 3C , Yo hi*ce esto gace alguun tiempo,(usando un opkeys hex file en ese tiempo) para ser capaz de tener acceso a PB canales bajo un diferente provider ID.(ellos tenian este en 0905 y tambien en 0906 en ese entonces) en uno de los grandes companias provedoras de satellite TV,antes de el ultimo bin de A/R para ese provider.
Sometimes it can be useful to manually add a provider ID under the code menu to enable the entry of additional encryption keys that may not already be included, to allow the viewing of additional encrypted content like RTN on Galaxy 3C, for example. I did this a while back (using an Opkey.hex file at the time) to be able to access the PB channel under a different provider ID (they had it on 0905 and even on 0906 at one point as well) on one of the big satellite provider's networks, before the latest bin file supported autoroll for that provider.
Here is how you do it:
aqui esta como se ha*ce.
1) First, arrow left or right to pick the correct encryption protocol for the key you're adding, such as Nagra.
Primero la flecha lado izquierdo o derecha para escojer el correcto protocolo de encripcion por la key que tu estas agregando,tales como Nagra
2) Hit F1 and enter the name of the provider.
Presiona F1 key(del remoto) y entra el nombre del provider( usa Amaz. )
3) Hit F2 to save it.
Presiona F2 para "save"
4) Enter the Provider ID (01 06 00 and Save)
Entra Provider ID (01 06 00 y save)
5) Finally, you must hit the SAT button to save it (this isn't shown at the bottom of the screen like the other steps are).
finalmente tu debes de presionar el boton de SAT(en tu remoto)
Note that this does NOT mean that autoroll will now work for that provider if it's not supported, but you should be able to view/listen to the channel as long as you have a currently valid key entered for the system that they're using.
Nota esto no significa que A/R debe de trabajar para ese provider si este no es suported(A/R) pero tu puedes ser capaz de ver/oir los canales siempre que tu tengas las keys actualizadas para el sistema que ellos estan usando.
Thanks goes out to Cyphris and Txsgent for this information
Las gracias a Cyphris y a Txsgent por esta informacion.
Detailed Extra Instructions
Instruciones extras y detalladas.
Presiona Main Menu->Code->Autoroll OFF
2) ve a Installation->Code->Nagra , ya dentro de este presiona F1 en el remoto para crear el nuevo provider.Escribe Dish o el nuevo nombre del provider,entonces presiona el boton SAT para "save" entonces en numeros en el lado Izquierdo escribe 01 06 00 o el nuevo provider ID numero y "save"
2. Go to Installation -> Code -> Nagra. Inside this menu press F1 on remote to create new provider. Write Dish or new provider name, then press Sat Button to Save then in numbers on the left, insert 01 06 00 or the new providr ID number. Save.
3. You should see 8 pairs of FF. With cursor go to first pair and insert 10, then select last pair and press FAV on remote to create the new key.
Tu veras 8 pares de FF. Con el remoto ve al primer par y pon 10, entonces seleccionas el ultimo par( de FF) y presiona FAV en el remoto para crear la nueva key
4. On new key, go to first pair of FF and insert 11. then select last pair and press FAV to create new key.
En la Nueva key, ve al primer par de FF y pon 11, entonces seleccionas el ultimo par (de FF) y presiona FAV para crear nuevas Keys
Ve al primer par y pon 20, luego a el ultimo para( par de FF y ultimo par de FF) y presiona FAV para crear la final Keys,
Ve al primer par(de FF ) y pon 21, ahora tu veras esto de abajo en la pantalla(TV)(ya creastes el provider ID 73 06 00 de amazonas.
7. Press exit to save.
Presiona exit y "save
8 Regresa a Options y pon ahi A/R en ALL
Despues de ha*cer esto tu VS trabajara igual.
Y veremos que pasa cuando cambien las keys
Si tu no estas seguro de que para que es esto, no lo hagas,
Esto es para experimentados usuarios o los que se atrevan a testear.
Esto es para experimentar.
Come back with the result.
Username: Chumley
Post Number: 808
quote:
Chumley
Username: Nydas
Post Number: 17347
Good post, Plymouth.
C801 and C901 will not make a difference.
Username: Plymouth
ModeratorCanada
Post Number: 12247
Cumley, Nalin
Yes laughlin must set both C801 and C901 to get all available channels
The good key line is 00 then 01.
Username: Boss_hog
Post Number: 131
Nalin Nyda
Username: Nydas
Post Number: 17347
Posted on Tuesday, January 05, 2010 - 08:25 pm:
C801 and C901 will not make a difference. Yes laughlin must set both C801 and C901 to get all available channels Upload
Username: Plymouth
ModeratorCanada
Post Number: 12261
Mr Sadman
Like I said "Yes and No"!
It work even if you put only one of both, but he will not get all available channels!
Post Number: 94
Ok after this onslot of post , i'm more fu@k than i was when i posted this message, i'll figure it out sometime within the next decade lol
Username: Xbucklawx
Thanks for all the help, i am now set up and watching the ponies, I just used the BEV option in NAGRA and inputted those numbers to get it up and running.
Username: Plymouth
ModeratorCanada
Post Number: 12282
meathead
Good!
It is a very good idea!
Congrat!
Username: Plymouth
ModeratorCanada
Post Number: 12290
Laughlin
Now you can try this way to get those channels!
