The END of KBOX
Username: Lacaliboy
Post Number: 42
Read about it ---> http://plzlink.me/a35
Username: Justforhohas
Post Number: 86
C/P
This is some news about Kbox. And it is not good. I was told that it is ok to make a statement like this even though there is not any doubt that it will cause an uproar. The person that I got my info from (Could that Guy be SUMP that has disappear)has been in contact with the kbox guys.
There are tons of folks out there that own Kboxes. Many that never got a minutes viewing pleasure with them. And to them, this will be very bad news unless there are some major changes. But in the eyes of my sources, more than likely Kbox will never be back up and running. I mean like 90% probability that they are done. That leaves only a 10% chance that they will ever be alive again. And if they do come back, it will be only for a very short time so hopefully they can sell some of the remaining stock.
"Hip, hip, hooray!" to the Number 1 and 2 helpers here that
were saying that Kbox and nFusion were the best receivers
for ISK and not to listen to these trouble makers they only trying to scare you
Username: Lacaliboy
Post Number: 43
KBOX isnt going anywhere
Username: Nydas
Post Number: 17295
IKS technology relies more on hardware and less of software writing. The hardware is very simple and the embedded software is much simpler to write than the "BINs" of last a year ago. So if kbox becomes defunct,
1. There is a good chance that the khub will be usable with another receiver;
2. Some "BIN" writer will write the necessary stuff to divert your to look for IKS in another direction.
In any case the impact of kbox not working will not be as sever as that of Viewsat not working last year. I am confident that some other group will come up and make your kbox and maybe a couple of other receivers workable.
Justforhahas was the promoter of Viewsats for 3-4 years and she should know.
Happly Learning!
Username: Plymouth
ModeratorCanada
Post Number: 12222
Nalin
I don't think that a new group will make Kbox workable because IKS cost $$$ to keep the sub's then support a old box does not give any $$$$.
Username: Doreenakadj
Ontario Canada
Post Number: 3496
Justforhaha's and Justfarhaha's are they the same person ? Just curious
Username: Nydas
Post Number: 17297
Doreen: Just send a PM to your friend LK and she will tell you.
Ontario Canada
Post Number: 3498
i can tell the difference ... can you?
Username: Brucester
Post Number: 1691
hello doreen how are you happy new year to you and your famley now let me say this if i had to bet on it i would say its him
have a greatday doreen
Username: Pirate_pete_209
Post Number: 254
Doreen even the Apache Indians wasn't
bother a crazy person
Username: Nydas
Post Number: 17301
Then why are you bothering Doreen?
Ontario Canada
Post Number: 3501
i don't understand your question Nalin.
Post Number: 260
He don't either
a real nut case
Username: Nydas
Post Number: 17308
Doreen: It is pure English.
"Then why are you bothering Doreen?" addresses somebody else.
"Then why are you bothering, Doreen?" would be a question to you.
