KBox pro H1 error?
Username: Lerika
Post Number: 19
Does not turn on, just H1 after back switch on. Can I fix it?
Username: Saqeeb9000
Post Number: 6502
use ur null cable download factory bin,
and download latest bin
Username: Lerika
Post Number: 20
What colour of cabel?
Post Number: 6503
the one that came with ur box..
Username: Lerika
Post Number: 21
There were black and grey, and do I need load program?
Username: Brampton_on
Post Number: 109
Lera Les
you should wait untill or if the box
comes back to life
right now it may just be a waste of tme
I had used the black null
but that was some time ago
good luck
Post Number: 6504
How To Fix K1-PLUS H1 ERROR
If your receiver has a H1 error on your led display, this is how to fix it.
1: Down load factory file and K1 Plus loader and unzip the following.
Link for Factory File:
Kplus K1 PLUS FACTORY files
Kpro K1 PROdigy factory files
Link for Factory Loader:
K1 Plus Loaders
K1 Loaders
2: Connect RS232 cable to the receiver and plug the power cord
from the receiver into the wall with the main power source off
on the receiver.
3: Open the loader on your desk top. Locate the factory file
with the browse button on the loader.
4: Now have your finger on the rear power button. Click it
to the on position. When you see the H1 error appear on
the display. Click CONNECT on the loader immediately. This may take a
few tries but the receiver will eventually accept the file.
5: Load the latest file and reconnect the receiver back up to
the your t.v.
6: Adjust all your dish settings and your good to go.
http://www.dssrookie.com/forums/k-box-guides-faqs/74346-how-fix-k1-plus-h1-error .html
Username: Nydas
Post Number: 17044
Prodigy uses a null cable which is often Black.
Username: Gregraf
Post Number: 4126
Dont look black to me.
Uploadhttp://images.google.ca/imgres?imgurl=http://www.shop4fta.com/images/products/kbox-k1-prodigy.jpg&imgrefurl=http://www.shop4fta.com/kbox-k1-prodigy-fta-satellite-receiver.php&usg=__19MfCgCVf-09HB2LXWMcDaK15eg=&h=400&w=500&sz=39&hl=en&start=2&um=1&itbs=1&tbnid=yRhFY8GxEmFeqM:&tbnh=104&tbnw=130&prev=/images%3Fq%3Dnull%2Bcable%2Bfor%2Bkbox%2Bprodigy%26hl%3Den%26rlz%3D1C1CHNU_enCA356CA356%26sa%3DG%26um%3D1
