110w signals on kbox
Username: Regrun2
Post Number: 81
hi guys,
i have kbox prodigy and i have a question regarding getting channels on 110w.. i used to get all the channels on 110w, but now i am getting no signal on all my 110 channels..
should i select Universal or Single for the LNB type? Are there any other settings should i use?
Thanks guys
Username: Sump
Post Number: 895
first ... u need to know what u have as lnb
but single and ocd are the popular ones
do u only have ONE lnb ? or One sat ?
is there switch ?
Username: Regrun2
Post Number: 82
there is a swtich.. i have one lnb for 110w
Username: Sump
Post Number: 896
why is there a switch and what brand model etc ... need the details .. do you know same for LNB
what are the sat settings ..
also note that some people are down on kbox @ the moment .. but u should be good siganls and be able to see DN ch 100
Username: Nydas
Post Number: 16618
110 channels are working fine on kbox using BIN version 212.
Your LNB should be set to single unless you have a Dish LNB.
Important you post the name of your LNB, and the existence of other LNBs in the system.
Username: Ekoneuno
Post Number: 52
Related to this, I have the dishes towards the following satellites - 110, 91 and 118.8 and which I have scanned in my KBOX. Do I need to separately scan 119 as well in my KBOX?
Username: Sump
Post Number: 904
yes if u have a 119 LNB setup but in above post it not there
Username: Nydas
Post Number: 16632
For LNB 118/119 disEqC was set to port 1.
118.7 scan - This particular LNB requires a "single" setting at 10750. The signal stregth and quality show green >80%. Autoscan works well.
119 scan - This particular LNB requires a "Universal" setting at 9650-10600. The signal strength and quality show green >80%. Autoscan works well.
These two setting will vary with different LNBs, as long as you use the special LNB designed for 118/119 and have a >30" Dish.
