Nfusion EPG help?
Username: Kosmo71
What is the best way to use the solaris eps auto or manual when I use auto it will load and give me an epg but in a little while if I hit the guide button it loads the guide again any help will be appreciated.
Username: Plymouth
Post Number: 10993
RK
I use manuel for the same reason.
Username: Kosmo71
are you talking about the users guide that came with my nfusion?
Username: Plymouth
Post Number: 10995
RK
I talk about the setting in Menu>Users settings>EPG Update and you choose Manual.
Username: Kosmo71
if I do that what channel is the best to leave it on so it will populate the guide thanks plymouth
Username: Plymouth
Post Number: 10997
RK
You don't need to be on a specific channel to populete the Guide, if a channel don't provide th EPG, you only select this one and press "i" (info") button and the guide will appear.
Username: Ram710
Post Number: 9
HI GUYS I AM TRYING TO GET MY NFUSION SOLARIS TO WORK BUT I CAN GET IT WORK II DOWNLOAD THE FILE BUT WHEN I HOOK IT TO THE TV ITSAY SERVICE IS NOT AVAILABLE IS SOMETHING I AM DOING WRONG
Username: Plymouth
Post Number: 11007
navin
You must do a factory default after you downloaded the file.
Username: Ram710
Post Number: 10
how you do the factory default thank you plymouth
Username: Plymouth
Post Number: 11008
navin
Menu>System Settings>Factory default
