Just Bought The Phoenix
Username: Jamesta
Post Number: 51
caved in. Can some one send me a link with the instructions on how to down laod the new bins when they are released. Thanks
Username: Plymouth
Post Number: 10966
Download this file:
http://currentbins.com/nfusion/Phoenix/
Then load it with this loader:
http://www.box.net/shared/jiu9u4me5i
Do a factory default, then press Menu>Internet>SW Update and load the latest file.
Scan your satellites like a standard receiver.
Username: El_toro_the_great
NC USA
Post Number: 47
Now this is what I call a good post.
No BS, No Bashing simple right to the point.
Keep your post like this one and maybe
the members here will stop fu*cking with you.
Username: Plymouth
Post Number: 10967
Whiskey
My posts are always like this!
I never started the bashing, if you read a little you will see it!
Many ppl will bash me for any reason, competitors, Dn or Bev guys and many others reasons.
Username: Asplover
Post Number: 167
Plymouth you are one of the best helpers i have seen on this site.
Keep the good work
Username: Rtf
Post Number: 94
Be nice to plymouth or he will banned you or have all your posts deleted or even worse. He will tell on you.
Username: Jamesta
Post Number: 52
So can i load this from my router or do i have have to connect the box up otherwise. You guys will have to walk me through this step by step. forgive my ignorance. thanks
Username: Plymouth
Post Number: 10968
asp lover
Thanks for your support!
James
I have not tried to load it directly from server, but I think that you must load the file to get good IP settings before.
Username: Hebertovich
Saint john, Nb
No you can hook it up, find it's IP, and load right from your your pc through the router. Very easy to do!
Username: Plymouth
Post Number: 10969
Mike
You have to put your router IP adress on a internet page then load it, I know how do it.
Username: Jamesta
Post Number: 53
so sorry guys. Would i down load the 2 sites that were given to me and then save then to the desktop and also how would the box be connected to your pc to do this. thanks
Username: Saqeeb9000
Post Number: 6002
plymouth u are the best..
james here's how you use webloader..
i posted it long time ago,
sada
Post Number: 3654
Posted on Thursday, August 14, 2008 - 09:08 pm: Edit Post
sada
Post Number: 3462
Posted on Thursday, July 03, 2008 - 07:42 pm:
what u need to do is go to menu , internet, then network information, find ur ip adress......
now write down ip adress at some paper..
now go to internet browser, in adress bar type ur ip adres. just like you type [link removed]
[link removed]
[link removed]
some hints .. when u are putting ip adress in adress bar, change the channel or some times tune in to 100 or 102 channels also help..
when u will type ur ip adress u wil get in to webloader, over there locate ur latest bin that u saved and then clik on upload wait 1 min........ and ur rec will turn off and on again..
to check if u have latest bin, check under menu system setting, it should says latestbin.
after thaat if u still not up, go to menu usersetting and turn off emulator and autorolls on...
this should work.....
https://www.ecoustics.com/electronics/forum/home-video/500222.html
Username: Jamesta
Post Number: 55
thanks man. So if i have the box wired up through my router this process will work?
Username: Plymouth
Post Number: 10971
James
Yes!
Put your Receiver in port 1 and choose this IP 198.168.1.1, then put your Router Username then Password.
Username: Sump
Post Number: 305
nope !!!
Username: Plymouth
Post Number: 10979
James
Yes!
Now you can access to your receiver and send the file without cable.
Username: Runnerguy
Pluto
Post Number: 1879
James! Do NOT listen to Plymouth. sump is much more qualified. I am pretty sure plymouth is a 12 yr old who takes drugs and may be very G@y.
Username: Plymouth
Post Number: 10982
zulu
Go play with your Tonka idiot!
