New member Username: PrisonerofsocietyPost Number: 1 Registered: Aug-09 | Are there any FTA sats where I can get these channels? KFMB-TV (CBS San Diego, California) KCBS-TV (CBS Los Angeles, California) KTTV (FOX Los Angeles, California) |
Silver Member Username: SumpEast coast USA Post Number: 117 Registered: Aug-09 | local aren;t available yet ... i think Nfusion has the National feeds of cbs,NBC,ABC. local can be had by using a simple NEW HD rabbit ears antenna GREAT picture too !! |
Silver Member Username: InformerPost Number: 130 Registered: Mar-09 | http://www.solidsignal.com/prod_display.asp?PROD=SS3000 |
Silver Member Username: AjdarwinPost Number: 299 Registered: May-06 | I understand what you are asking. It appears that the channels that were FTA, G10R for example, are disappearing from the sky. I went from over twenty channels to 3 or four. Most are still available on C band, but are scattered throughout the satellite band. I may be wrong, but I think some major changes are taking place in true FTA. |
New member Username: PrisonerofsocietyPost Number: 2 Registered: Aug-09 | Thanks for all the responses. I already tried the rabbit ears, bought a very expensive uhf/vhf antenna and also build my own one and still didn't work. The problem is that I'm located in Baja, Mexico, and there seems to be a huge hill that is blocking the reception to those local transmitters. I can recieve everything else, except for those specific channels. |
