Can't lock 61.5
Username: Sambhat
Usa
hi guys
I am not able to lock 61.5 satellite on nfusion phoenix. I have changed nothing with respect to the dish set up.
lnb type: standard
lo freq: 11250
22 khz: off
DiSEQC1.0: Port 2
DiSEQC1.1: Disable
Muti Dish switch: Disable
Lock Tp: [2/32]12239 H 21500
Motor Settings: Off
LNB Power: On
I am able to lock 110, 119 but not 61.5
Please help
Username: Chumley
Post Number: 515
the symbol rate of 21500 indicates HD ( can't get HD signal with nfusion phoenix)...
use a TP that has symbol rate of 20000
Username: Sambhat
Usa
just edited the 12239 to to 20000 symbol rate and rescanned.
Still no luck. After rescan it did not pick up any additional channels. I am looking for channels 611 and 614.
Let me know what else can I do.
Thanks for your help
Username: Chumley
Post Number: 516
You didn't need to edit that TP ,I was just letting you know that TP's with a symbol rate of 21500 will not have signal with the phoenix.
Try scanning TP 12414 and 12472 for channels 611 , 614..
Username: Plymouth
Post Number: 10513
Sam
I use 12326 H 20000, try this one.
Username: Sambhat
Usa
thanks but no luck on those two tps either.
S and Q never turns green
Username: Plymouth
Post Number: 10514
Sam
Where are you located?(state)
Username: Sambhat
Usa
Plymouth,
Thanks for your reply.
I am in NJ. I tried 12326 H 20000 but no luck
I hardly get any channels from 61.5 except for a few on 12632 for which the S and Q turn green.
Username: Sambhat
Usa
Plymouth,
When I look up lyngsat, I should be getting a few channels 12472 which includes channel 614 but I can't get signal on this tp.
Username: Plymouth
Post Number: 10517
Sam
Realign your dish.
Username: Sambhat
Usa
Post Number: 7
Thanks but that would not be easy is it?
This is a fixed dish. Any suggestions on easiest way of doing this by myself?
Username: Plymouth
Post Number: 10518
Sam
The best way is buy a cheap satellite tracker that you hook between the lnb and receiver and try to get best signal.
You can also check only your connexions unhook and rehook all cable between this lnb and your receiver.
Username: Sambhat
Usa
Post Number: 8
Thanks Plymouth.
Any suggestions?
