New member Username: Dusty1980Post Number: 5 Registered: Jul-09 | i was looking on ebay to buy one of these boxes it doesn't really say what comes with the box so i was worndering what all do i need to get one of these boxes to work.......... |
Platinum Member Username: PlymouthCanada Post Number: 10388 Registered: Jan-08 | fta newby You have to buy only the receiver, these receiver are Ethernet build-in. The Solaris and Phoenix are for SD channels and the Nuvenio is for HD channels, both work on Bev and Dn. Here is the best site for buying a NFusion in USA and Canada. Choose the option that you will need. |
New member Username: Dusty1980Post Number: 6 Registered: Jul-09 | Do I need to buy a router with a nfusion solaris |
Platinum Member Username: PlymouthCanada Post Number: 10412 Registered: Jan-08 | fta newby Yes buy the cheaper D-Link, you need a high speed internet. |
New member Username: Dusty1980Post Number: 7 Registered: Jul-09 | im waiting on my nfusion solaris should be here in a day or two..i all ready have high speed and a router is there anything else i will need to get this thing running......and if anybody knows where to find some very easy installation directions it would help me a whole lot.........thanks for all the help |
Bronze Member Username: Plymouth_glasserPost Number: 57 Registered: Apr-09 | http://www.docstoc.com/docs/2432985/NFUSION-STEP-BY-STEP-FOR-NEWBIES |
New member Username: Dusty1980Post Number: 8 Registered: Jul-09 | when buying a new box from |
Platinum Member Username: PlymouthCanada Post Number: 10451 Registered: Jan-08 | You hook it on internet thern put the latest bin file then do a factory default and scan your satellite. |
New member Username: Dusty1980Post Number: 9 Registered: Jul-09 | ok thanks......and one mor question plymouth i read that the solaris was a standalone box but there were not going th have any support for the standalone is there any truth to this???????? |
Platinum Member Username: PlymouthCanada Post Number: 10452 Registered: Jan-08 | NFusion not support stand alone since many months If you buy this box, you will always be up before others This is a very good spare box. |
Bronze Member Username: AbeyambuPost Number: 35 Registered: May-06 | plymouth : on the nfusion web they offer the receiver i think solaris wich says internet ready fta, ethernet port. then they offer wireless kit as an extra. do you think it is worth it. |
Platinum Member Username: PlymouthCanada Post Number: 10454 Registered: Jan-08 | Abe If you can't use a cable, yes! |
New member Username: Dusty1980Post Number: 10 Registered: Jul-09 | if the motherboard has been changed with a nova how could you tell??and is |
Platinum Member Username: PlymouthCanada Post Number: 10463 Registered: Jan-08 | You can buy it on E-Bay, I posted this site only to see the option that you can buy with the receiver, buy the Phoenix if you don't trust the Solaris. |
Bronze Member Username: Dusty1980Post Number: 11 Registered: Jul-09 | i used the site you gave me and bought the solaris. i was just reading and someone said they had been done like that it just worried me a lil but since you recomended the site i feel pretty safe......thanks again plymouth i would be in the dark if not for you help........... |
Bronze Member Username: Dusty1980Post Number: 16 Registered: Jul-09 | i was just reading that some routers wont work with nfusion is this true because i just bought a belkin model v-1 will this one work 4 me.........thanks |
Platinum Member Username: PlymouthCanada Post Number: 10509 Registered: Jan-08 | fta newby Here is a router list posted by Sada: sada Gold Member Username: Saqeeb9000 Post Number: 5449 Registered: Oct-07 Posted on Saturday, June 20, 2009 - 09:42 pm: Edit Post Updated list of Routers known to work with nfusion Please find below an updated list of Routers known to work with the nfusion receiver. This list was compiled from data collected directly from nfusion users/owners: __________________________________________________ ________ Apple's Airport Extreme Base Station. AT&T 6800G belkin wireless g belkin wireless n belkin pre-n belkin f5d8233-4 n Belkin Wireless G Model F5D7230-4 (hardwired) Buffalo WHR-HP-G54 D-LINK VWR-vd D-LINK DI-524 D-LINK DI-6041 D-LINK DI-614+ D-LINK DI-624 D-link 625 D-Link Model DL-704 D-LINK DI-704P D-LINK DI-704UP D-LINK DIR655 D-LINK WBR-1310 D-LINK WBR-2310 DYNEX dx-esw5 LaFonera 2 Port Wifi Router LINKSYS BEFSR41 Linksys BEFSR41 ver 4. LINKSYS BEFW11S4 LINKSYS WAP55AG LINKSYS WRT150N LINKSYS WRT300N LINKSYS WRT350N Linksys WRT600N with DDWRT Firmware Linksys wrt54G version 5 router Linksys WRT54G with DDWRT Firmware Linksys wrt54gc Router with Netgear XE-102's LINKSYS WRT54GL V.1.1 Linksys WRT54GL with Tomato FIRMWARE (MLPPP version) Linksys WRT54Gv8 with Netgear XE102's Linksys WRT54Gv8 (set to WAP-2) LINKSYS WRVS4400N Linksys Wireless G Model WCG200 with Netgear XE102's Linksys WCG200 Cable modem and wireless router all in one Linksys WET54G wireless bridge with WRT54G Linksys WET54G wireless bridge with a Dlink 528 wireless router. Linksys Wireless-N Model WRVN4400N Linksys Wireless B 2.4 Model BEFw11S4 Linksys WRT54G router and Linksys Wireless Music Bridge WMB54G using Wpa Personal 2 security. Download new FIRMWARE and software for Bridge first from Linksys site and upgrade before installing bridge. NETGEAR WGR614 NETGEAR WGPS606 NETGEAR WGR614 Netgear Range Max Model WPN824 with Netgear XE-102's Netgear WPGS606 (Bridge) Netgear Wireless Router, Model WNR854T with Netgear XE102's Netgear WGR614 with print server NEXLAND PRO800 TURBO Seimens gigaset se567 modem/router SMC Model WBR14-G. TP-Link Model WR340GD TP-LINK TL-WR 642G wireless Trendnet TEW432TRP Wireless Router WESTELL VERSA LINK 327 WESTELL Model D90-327W30-06 and others................... |
