Nfusion solaris help
Username: Kickboxer1st
Post Number: 13
Hello everyone... Recieved my nfusion solaris today and have downloaded all the essential files. Just quick question does the solaris have a built in wifi? Based on my house design I can't wire it to the router. So what are my options of running the solaris wireless? Thank you. Any help will be greatly appreciated.
Username: Plymouth
Post Number: 10479
kickboxer
You can buy a PowerLine wireless extender kits like this one:
Post Number: 14
Thanks Plymouth for quick reply... How much do those run for?
Username: Plymouth
Post Number: 10482
Sorry I forget to post the link:
http://www.netgear.co.uk/extra/wallplugged_range_extender_wgxb102.php
http://reviews.cnet.com/bridges/netgear-wgxb102/4505-3304_7-31119874.html
You plug it in your power inlet and hook the rooter then the receiver.
Post Number: 15
Is that my only option Plymouth?
Username: Pirate_pete_209
Post Number: 9
Plymouth with over !0,000 posts I would say
that you are without a doubt an accessory
to piracy.a reward or not it would be worth it just
to make you eat your own words.You smart azz SOB.
You have lied, rat and disrecepted the seniors members here long enough
The Royal Canadian Mounted Police invites citizens to report any information on illegal activities by local individuals or groups involved in such offences by calling 418 698-5666 or Info-Crime Québec at 1 800 711-1800. All tips will be kept confidential
Username: Plymouth
Post Number: 10485
Yes if you can't use the cable
Do a serch on google on "wireless Adaptor" or "Turbo 85"
On Nfusion they have one for 89.99$
http://www.nfusion.ca/
Username: Plymouth
Post Number: 10486
Fock you Captain Hook!
Post Number: 16
Thank you so much for your help Plmouth! I however have a pc connected to my hd tv which is wifi enabled and I read somewhere that if you can bridge the pc and nfusion, that should also work. I was able to bridge my wireless and nfusion but the IP is stilll 000000. Can Plymouth or anyone else help with that please?
Username: Plymouth
Post Number: 10488
kickboxer
For best result and be sure that it work, I recommend that you hook it directly in the router before and make that it work fine before, and after it, try your bridge.
Post Number: 17
Thank You for your quick replies and patience with me Plymouth :-) I was able to get nfusion working by bridging it to a near by computer which was wireless. Saved me a lot of money though hehe.
Username: Plymouth
Post Number: 10490
Your welcome kickboxer!
Good news, this can help other users.
