Pansat2700a autoroll help
Username: Imran4811
Richmond hill, Ny AMERICA
Post Number: 67
i just got the new bin file i think its just fine, but am getting autoroll keys on the screen how can i turn autoroll key on and where exactly it is
Username: Chumley
Post Number: 350
It is located in cas menu
menu , parental control , second pin - enter pin code and you will see it.
also while on a channel enter 8282 - shortcut to cas menu
the unit will find the new keys with autoroll turned off, too
Username: Nydas
Post Number: 15304
After you enter second Pin (usually 0-0-0-0), click on the last item. There you will see autoroll for
BEV
DN
Globecast
