KBox
Username: Frobi
Post Number: 353
Internationals on 118 down?
Username: Rafiq128
Post Number: 197
same here
Username: Topy
Post Number: 64
New file posted, pls download,,, but still channels are not coming, why? I don't know, probably SADA knows
Username: Topy
Post Number: 65
please post if any development arise... thx
Username: Saqeeb9000
Post Number: 5354
guys working fine here,
reset the hub
make sure latest file is downloaded,
there is new feature with the latest file exculisevly for k1plus member called weather forecast..
details after the game
Username: Frobi
Post Number: 354
Download file right from IKS?
Post Number: 5356
neil use ur usb..
Username: Frobi
Post Number: 355
sada, which file for Kbox plus? Could not find it.
Thanks
Post Number: 5357
http://www.dssrookie.com/forums/k1-plus-files/98625-k1plus_200_20090616-a.html#p ost580736
Username: Frobi
Post Number: 356
Thanks sada.
Post Number: 5358
u are welcome neil..
Username: Rafiq128
Post Number: 199
weather forcast working, for canadian cities.
i live in mississauga, i got it working.
Username: Frobi
Post Number: 357
Bhatti, how did you get it working? I tried to download for Waterloo, but can not download anything. Only shows for BC, Canada
Username: Mailbox4you
Post Number: 16
What is the staight forward steps to upload this file, just use the USB stick or I will loase all my settings and channels??/
Post Number: 5360
menu, data transfer, save ur channels list mc
this way u will never loose it,
then just upload new file..
even if u download, u won't loose ur channel but just to be safe..
