Pansat 2700a remote problem.
Username: Haders
The remote for my 2700a works only intermittently.
It's normally OK when I turn on the box but quits after a while, and may or may not start to work again.
I've replaced batteries but no joy.
Any ideas?
Thanks
Username: Bazuka2020
Post Number: 724
Load factory bin and reload the bin again and get rid of all the p*rn channels which are not working anyways
Username: Getmo96
Post Number: 129
Juat do a factory reset and reload the 218 bin .... you dont need to do all that stuff
Username: Satopia
Post Number: 388
if that doesnt fix your issue trust me i bougth a 2700 new about 5 months later remote failed purchased new one for it for 16.00 usd or theres cheaper ones on ebay for around 5.95 +shipping
