Nfusion wireless connection to routor
Username: Zakaziko
Toronto
My wireless connection seems to be affected by florescent lights and some "touch switch bedside lamps". My viewing is almost constantly getting interrupted by freezing. I am not sure it is the Nfusion server or something wrong with my set up. I can not have long Ethernet cable directly wired to router to be sure. Any intelligent answer? May be SADA
Username: Riconissan
Post Number: 1138
ziko ziko
First turn off the florescents and unplug the touch switched lamps and anything that you believe is causing the problem. Then start plugging them in one by one until you find the culprit.
You may have to use a wireless router instead of the house electrical wiring.
Username: Saqeeb9000
Post Number: 5151
ziko zeko
wireless or wire?
u said u use network cable that plugs from ur router to ur nfusion rec
or you use ethernet adapter?
how far is ur network cable from ur nfusion?
is it for example in 2nd story from main floor?
that could be the problem
i just finished watching 20/20 cricket on nfusion and it never even blinked..
if u are using ethernet adapter
make sure u plug ur both ethernet adapter directly into wall outlet (no surge protector etc)..
Post Number: 1142
He said he was looking for an intelligent answer.
Username: Zakaziko
Toronto
The Rec and the wireless router are a floor apart. I connect them using Ethernet adapter utilizing the wiring of the house. No surge protectors. But I have the problem occasionally. Is it possible to use my wireless router to connect to the REC without the adaptor? That adaptor seems to interfere with many things.
Thanks Rico n Sada
Post Number: 5153
rico my bad i didn't read the question properly,
u can only wireless router depending on where is ur modem..
Username: Mzakcat
Post Number: 140
plenum cable situation?
Post Number: 5158
zak why don't u try this first try network cable and see if u still have problems this will gives u idea that if problem is with ur adapter or ur rec?
the other thing u can do is plug ur network adapter in ur desktop / laptop and see how is ur internet connection are u getting constant internet connection using ur adapter or u loosing internet connection.
Username: Zakaziko
Toronto
I will try that. Thanks Sada. I do not have a laptop. i need to borrow one from a friend first.
Thanks
