Bronze Member Username: Nels2k
Post Number: 64 Registered: Mar-06
Posted on what LNB would be used for catching 101 AMC4. is it the same lnb used for 110 or is it like the 121 lnb. |
Gold Member Username: Plymouth
Post Number: 9610 Registered: Jan-08
Posted on nel rib This is a Linear LNB as for 121W
Gold Member Username: Runnerguy
Pluto
Post Number: 1831 Registered: Sep-06
Posted on http://www.satelliteguys.us/free-air-fta-discussion/99408-problems-setting-up-am c4-101-0w-gt-s40-lnb.html |
Post Number: 9612 Registered: Jan-08
Posted on Zulu your link is useless and all infos can be ask here which I can easely answer. Nel If you want get both 97W and 101W you buy a used StarChoice dish on E-Bay which is 4 degree ready and work fine for it.
Pluto
Post Number: 1832 Registered: Sep-06
Posted on Your Welcome!! |
