Nfusion set up
Username: Rockman169
Post Number: 75
before i start do i need to put the current bin file on it . and can i use a memory stick . can any on help me out or know where i can read up on it . thanks
Username: Saqeeb9000
Post Number: 4887
Your New nFusion:EVERYTHING YOU NEED IN ONE PACKAGE Step1.open box Step2.read this
[link removed]
Post Number: 76
thanks sada, but i am having trouble opening the set up guides on that site. i have all the files and the loader and iam able to set everything else up but i just need to know which files to load first, the boot file or the main program file. i have set up sonic view and viewsat before but the more i read about nfusion the more confused i get. thanks
Username: Gregraf
Post Number: 2873
boot file first then you will be able to load the other.
Post Number: 4895
check ur version first , if 1.30 is already there then u just need to download latest bin,
either way its not going to hurt ur rec if u download any file,
Post Number: 77
thank i got her up and running .and thank again for the help
Post Number: 4899
u are most welcome rockman
