Hello, I experience frequent freezing on Echo6/8(110). I am using the bin file 2.29 [2009-05-06]. Can anybody confirm having similar symptoms? what is the fix? Please post reply. Thanks.
Reload the file, If you have many channels which you don't use delete them and your receiver will work faster, you can do a factory default then rescan all satellite but you can lose few channels.
