New member Username: Dm8000Post Number: 1 Registered: Apr-09 | c/p @ ihadna.com Final Release of Eurocamd v1.0 At last, we have the official release of Eurocamd v1.0, and it is strictly for active ihadna supporting members. What is Eurocam? - It is the first & only cardless solution for Irdito2 & Nagravision3 "No support for Nagravision2" - It is designed for The Gemini Project ONLY in flash, do not try to run it on any other image, or on Gemini in Multiboot. - Since each box get its own binary compiled, do not try to use a copy from one box on another box, it will kill your box. (READ BELOW) This is how it works, you have to provide to us your legitimate "not clone" Dreambox exact model and mac address numbers, these numbers will be added to the binary before compiling, and this way, the emu will only work for just that box. No one can imagine the kind of work that we put into Eurocam, and this would be the only way we can think of to make sure it doesn't fall in the hands of Clone Dealers, as we strictly support Dreambox. As we speak, the official release is for Enigma1 boxes, except the DM500, the DM56X0 & the DM7000, which we have no plans for due to memory limitation. Enigma2 release will be delayed for a few more weeks for tweeking "adding support for the DM8000 with 3 tuners". Please do any requests for the cam in email to eurocamd@googlemail.com with include following information: Your ihadna user name Your email address Your Dreambox exact model number Your Dreambox exact mac address |
Silver Member Username: JoeturnPost Number: 225 Registered: Apr-06 | Hog wash, just a sales pitch$$$$$$$$$$$$$$ |
Silver Member Username: Redwater71Post Number: 103 Registered: Sep-06 | Sounds more like, send me your address and I'll send you the money .. I promis ! SCAM ! |
Gold Member Username: PlymouthCanada Post Number: 8797 Registered: Jan-08 | Here is the original link: http://www.novisf.com/wbb3/index.php?page=Thread&threadID=74106 |
Gold Member Username: PlymouthCanada Post Number: 8798 Registered: Jan-08 | Will work with this very heavy receiver with 300 MHz processor and 128 MBytes DDR then 32 Mbytes flash memory. PROD_DET_DESCRIPTION Dreambox 7025,DM 7025 Cable satellite receiver Powerful receiver for digital TV and Radio programs. 300 MHz processor, Linux OS and Linux API support. DreamBox 7025 Features: 300 MHz Processor Linux open source (most parts under the terms of GPL) Supports Linux Standard API 1 x DVB Common-Interface Slot 2 x Smartcard-Reader Integrated Compact Flash Interface Slot MPEG2 Hardware decoding (fully DVB compliant) TWIN Tuner, mixable, Plug&Play Tunervarianten DVB-S, DVB-C und DVB-T, pluggable 10/100 MBit compatible Ethernet Interface USB Port 12V switch cinch V.24/RS232 Interface Big-size LC-Display 32 MByte Flash 128 MByte DDR-RAM integrated IDE UDMA66 Interface Support for internal HDD in any capacity unlimited channel lists for TV/Radio channel-change time < 1 second full automatic service scan supports directly bouquet-lists supports EPG (electronic program guide)' supports multiple LNB-Switching control (supports DiSEqC) fully adaptable OSD in many languages and skin-support S/PDIF Interface for digital bit stream out (AC-3) 2 x Scart-interfaces RF modulator Audio/Video cinch out MINI-DIN connector for extern IR (send) DreamBox 7025 technical data DBS-Tuner: Frequency Range 950 . 2150 MHz Signal Level - 65 dBm . - 25 dBm Signal-to-Noise Level 12 dB max. DBS-Tuner Input Connector F-Type female Input Impedance 75 Ohm AFC +/- 3 MHz Demodulation Shaped QPSK FEC Viterbi and Reed-Solomon Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation Roll-off Factor 35 % Demultiplexing according ISO 13818-1 Common-Interface: Common-Interface Power Consumption max. 0,3A/5V Video decoder: Video Compression MPEG-2 and MPEG-1 compatible Video Standard PAL G/ 25 Hz, NTSC Video Formats 4:3 / 16:9 Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart) Letterbox precolating for 4:3 TV-Device Audio decoder: Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3 Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz Output analog: Output Level L/R 0,5 Vss on 600 Ohm THD > 60 dB (1 kHz) Crosstalk < -65 dB Output digital: Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output optical (AC3) Video parameter: Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard> TV-Scart: Output: FBAS,RGB,S-VHS over OSD selectable VCR-Scart: FBAS Serielle Interface RS 232: Typ RS232 bidirectional Bitrate 115,2 kBit/s max. Plug Connector SUB-D-9 Function: Update of Firmware Ethernet: 10/100 MBit compatible interface Function Update of Firmware, Connect to PC USB: USB 1.1 connector Mini DIN: I2C for stearing of external devices IR funktion Pins: 1 5V 2 SDA (I2C-Kanal 2) 3 SCL 4 3.3V 7 GND 8 IR-Output 9 GND UDMA66 IDE Interface: Intern for connect HDD max. 500mA Compact Flash - Reader LNB power and polarisation: LNB Current 500mA max. ; short-circuit-proof LNB Voltage vertical <14v> 11,5V at 400mA LNB Voltage horizontal <20v> 17,3V at 400mA Count of active satellite position: DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION DiSEqC - Rotor Control Power consumption: < 30W (in operation, horizontal polarization / 400mA LNB current) < 25W (in operation, without LNB) < 2W (Deep-Standby-Mode) Input voltage: 230V / 50 Hz alternating acurrent +/- 15% 110V / 60 Hz alternating acurrent +/- 15% Physical specification: Ambient Temperature +15A°C...+35A°C Humidity < 80% Size (W x D x H): 374 mm x 230 mm x 75 mm Weight: 1,8 kg without HDD The DreamBox 7025 product has been tested for over 12 months by hundreds of users and turned out the most reliable product among the solutions of a kind. Our DreamBox 7025 is a new highly stable and reliable hardware product, based on a new thoroughly tested hardware platform which has proved to be extremely safe and efficient even after months of heavy tests under extreme loads. |
Silver Member Username: RiconissanPost Number: 652 Registered: Feb-09 | But does it work with N3? |
Gold Member Username: PlymouthCanada Post Number: 8800 Registered: Jan-08 | Rico If you read the first post: yes But we have to see it. """- It is the first & only cardless solution for Irdito2 & Nagravision3 "No support for Nagravision2" """ |
Bronze Member Username: DirectmcPost Number: 17 Registered: Dec-07 | EuroSCAM v1.0 |
