BEV: BEV is broadcasting under nagravision 3 security and not visible on most FTAs. Nfusion and a few other IKS receivers are able to show BEV channels. please check the appropriate thread for detailed information on what is visible.
DN. As on 6th April, 2009, all Adult channels have gone over to Nagra 3 and are not visible. Most Internationals are also under Nagra 3 and not visible. Please note that NONE of the DN channels under Nagra 3 are visible under ANY FTA receiver.
If you are not seeing any channels you were seeing before try and see if the channels fall under the category of Nagra 3 encoding.
Also, on some receivers at least, a manual entry of the latest keys www.tvkeys.com is all that is necessary or wait on channel 200 with autoroll on.
