Samsung DLP HL-R5064W black screen with sound
Username: Edoctoor
Model HL-R5064WX /XAC
I was watching TV and the screen changed to a black screen. No popping sound, just black.
I turned the TV off and on and there was sound but the screen it black. I can see that the two fans near the lamp and chip are working. I can see the lamp is on but the screen is black.
I called Samsung they told me that nothing was recalled for my model.
Is there a page here that has a list of tests that I can try to determine or locate the cause of this epic Samsung DLP failure?
I also have a HL-R5066WWX /XAC if switching parts are an compatible debugging option.
Also some information of where I can get the service manual and parts would be very helpful.
Need to Register?
Forgot Password?
Enable HTML code in message
