PANSAT 2700A HELP!
Username: Statboy
Post Number: 83
I have loaded the new BIN 211 on my orginal Pansat but I keep getting scrambled or bad channel, what can I do to fix this?
Username: Nydas
Post Number: 14725
1. Hard reset.
2. Load again.
3. as soon as you get into the receiver do 8282 and "set default keys.
Username: Statboy
Post Number: 84
How do you do a hard reset and also what do you mean by 8282 and set default keys? Can you please give me an example?
Username: Dimwitt
Post Number: 1207
Hard reset = off/on via switch on back of receiver
8282 - while on a channel enter 8282 and it will take into the menu, you select 'set default key' , exit out of menu and wait on a channel for the keys to autoroll
Username: Riconissan
Post Number: 605
Sounds like a lot of work. with my 4 (Four) Viewsats I just load the bin. and enjoy TV.
