Is viewsat supposed to be freezing?
Username: Legend_killer
Post Number: 107
well our viewsat plat has been freezing since wed or earlier, ummm i read doing a hard boot and leaving it on one channel for 30 mins since they keys are changing will fix the prob, but no luck..
Username: Nydas
Post Number: 14807
Is your autoroll on? Try with autoroll on.
Username: Riconissan
Post Number: 624
Viewsat Plat and PVR no freezing with 090227 bin.
Reload this file and do a hard reset.
Post Number: 108
how would i do a hard reset? same as hard boot is it?
yeah my autoroll is set to all so yeah.
Username: Nydas
Post Number: 14809
Hard reset simply means turn receiver OFF at back, wait for 30-40 seconds and switch it ON again.
Post Number: 625
Ali,
Hard reset is turning the power switch that is on the back of the receiver off then back on.
I was mistaken, VS Plat is working with the above file. VS PVR is freezing. I will test some other bin files.
Plymouth, Do you know which file is good?
Just back from Costa Rica.
Post Number: 626
Nalin? Any proven bin for VS PVR?
Post Number: 110
i just loaded the 090227 bin but its still autoroll processing.
Post Number: 627
Ali,
are you using an ultra?
Post Number: 111
no, platnium
Post Number: 628
I have access to 3 Platinum lite none of them are reporting freezing.
Post Number: 112
ohh serious, i was on the march 3rd bin, which had the freezing.
Post Number: 629
I have yet needed to load the march 3 bin. Usually I just need to rest and reload 090227.
Post Number: 113
i did load the 090227 bin but then the ---- came up so i loaded the 090227-1 bin and that had autoroll processing as well, so i loaded now the latest bin 090407.
Post Number: 630
Never mind Nalin.
Factory default and 090309A solved the freezing problem for VS PVR7000.
Post Number: 631
Ali,
is 090407 working?
Post Number: 114
:lmao
Yeah, 090407 is working fine, Papi.
Post Number: 632
Ali,
Strange.
Not that the April 7th bin is working, just that I am having no freezing with Feb 27th file.
Glad you are up.
Username: Plymouth
Post Number: 8680
Sorry for late reply
Guys I use 09/03/05 bin since out without any problem, the only problem I had is slow autoroll which I only reload this file and all comeback.
With Viewsat beward with the hard reboot, because you will lost all channels and kill your receiver.
So always reload the bin before doing a hard rebot.
