Bronze Member Username: AbeyambuPost Number: 25 Registered: May-06 | is it possible to get channels from this bird.? i am located in panama. i use a viewsat ultra. do the same gear would get the tps.? i ubderstand its used by sky or DTV, dont know what encryption use. |
Gold Member Username: PlymouthCanada Post Number: 8391 Registered: Jan-08 | Abe Yes you can with a Viewsat Ultra and a 4' to 6' dish, the encryption is Nagra2 and the keys are available. |
Bronze Member Username: ThorontoPost Number: 69 Registered: Jun-06 | Are there more information on this, such as dish position, type, and where to get the keys? I am going to Brazil in July, I wouldn't mind testing. thanks. |
Gold Member Username: PlymouthCanada Post Number: 8392 Registered: Jan-08 | Thoronto You use a Ku dish and a Linear LNB. Use dishpointer.com for aimed the dish, all infos for aimed is there. you can get the keys at http://livekeyz.com/ |
Bronze Member Username: ThorontoPost Number: 70 Registered: Jun-06 | Thank you. (-: |
Bronze Member Username: AbeyambuPost Number: 26 Registered: May-06 | PLYMOUTH :i am located in panama. i get birds 110 and 119. my antena is around 5 feet. so i should get it with same arrangemnt as i have for DN? once locate the 61.5 bird? |
Gold Member Username: PlymouthCanada Post Number: 8397 Registered: Jan-08 | Abe A 5 feet dish can work but you need to use a Linear LNB. |
Bronze Member Username: AbeyambuPost Number: 27 Registered: May-06 | what is the diference between a linear and a circular lnb? |
Bronze Member Username: Boss_hogPost Number: 70 Registered: Oct-08 | abe rais Linear LNB receives Frequencies that are transmitted in horizontal and vertical polarization Circular LNB receives Frequencies that are transmitted in Circular polarization |
Gold Member Username: PlymouthCanada Post Number: 8430 Registered: Jan-08 | Abe check on Lingsat. com when you see "R"( Right) and "L"(Left) this is Circular and "V"(Vertical) and "H"(Horizontal) this is Linear. |
New member Username: JborregoPost Number: 3 Registered: Nov-06 | Hey Guys I want to upgrade tu HD, but don't know which receiver buy, can some one tell me the best to and where, I'm in Montreal.. |
Silver Member Username: RiconissanPost Number: 583 Registered: Feb-09 | Albert B, I would Wait. Quite a few of the channels have gone to new encryption. I believe it would be a gamble to upgrade. |
