New member Username: NidzPost Number: 7 Registered: Mar-09 | ok people here is my problem by mistake i loaded pansat puff LZMA on my pansat 2700a and after loading it my receiver gone blank it got stuck on #5 and its still there its totally blank tell me please help me what to do |
Platinum Member Username: NydasPost Number: 14686 Registered: Jun-06 | You should be able to revive it. Look at my post just a few minutes ago at the following URL. https://www.ecoustics.com/electronics/forum/home-video/558791.html |
Bronze Member Username: Peeps365Post Number: 29 Registered: Feb-09 | you should use the cleaner if the box accepts it then put the latest factory bin on it and then load the latest fix and u should be good to go}\red}} |
