Compaq Presario Laptop
Username: Mati
Post Number: 47
Dear Sir,
Problems with Compaq Presario V2000
Computer give me blackscreen only power ligth on ?
Appreciate your support
Regards,
Eugene
Username: Satopia
Post Number: 359
migth be a bad connection from mointer to motherboared that or your video card is shot
Username: Mati
Post Number: 48
Mr.Vann
Appreciate your prompt respone,
how can i dismantleit computer compaq presario V2000.
Thanks
Regards,
Eugene
Username: Mrgreg
Post Number: 337
yugene,This is a satellite forum not a computer repair shop.
Username: Satopia
Post Number: 361
Go here yugene it should help you in your task http://www.screentekinc.com/lcd-removal-instructions_en,compaq,step5.shtml
Username: Mati
Post Number: 49
Dear Sir,
I will be Happy for your Support.
Thank You.
Best Regards,
Eugene
Username: Dude123
Post Number: 2408
This is the correct forum go here and they may be able to help you out there...and give a little more details
https://www.ecoustics.com/electronics/forum/computers/8829.html
Username: Luser
Post Number: 415
There,s a bright adjust by holding blue key fn next to Ctrl+f3
