i m living in florida west cost and i love cricket so i bought new nfusion but can i get it 82w in florida ok satellite 82w [no netid] lnb type standard lofreq 11250 22khz off i dont use any diseqc lock tp [1/32]12224 v 20000 moter setting off lnb power on my s 85% and q 88% but bhatti one thing i tell u with this same seting if i use my old one viewsat box then i can get all 82w chanel but when itry with nfusion i cant get any chanel and if u use nfusion u know that if we can go in antena setting there r righ side littel box in sattilet line and say that lock or no netid and
sandy i will suggest u to move the diesqc to 1 or 2 , that can be the case, andn try it again, until it locks sat, make sure its nimq 2 not nimq1 u can lock tp at better signal, try turning off lnb power might work but i doubt it..
if this doesn't work try to these steps with network cable ( if u are doing it without network cable some time it doesn't work... if this does'nt work do factory default,relaod factory bin 3 times make sure u let it completly download and reload the latest bin..
i had similar problems 4-6 months ago, but mined scanned channel once i click on scan channels although it didn't lock the sat so then i tried agaiin with factory default and it worked..
ok one more thing i was reading the other thread of yours, well my setting are 91 diseqc 1 110 2. 119 3 and 82 is at 4 so u can do the same thing with that,
