It froze. I restarted it from the back. Since than it is just rebooting. I followed the instruction in the link below but it didn't work. http://www*hashhu*com/forums/showthread.php?t=199853 Can anyone help please? Edit/Delete Message
You must download factory bin with the Null cable from your computer . Go to: [link removed] download this 2 files: VSHD Loader - Firmware Updater v1.1( Serial) [link removed] And the factory bin: [link removed] for download with the loader in your receiver
Power off switch on receiver back panel open program take file v0107 clic D to download in receiver and a second after switch on the transfert take 5-15 mins you must see 0000 download the latest bin with USB
It can take many times with different delay. Good luck
Zagros, here .The Problem.... VIewsat MaxHD Boot Init Check H/w
I read some Forums and I tried whatever it asked but I still can't get out of Boot Loop for Max HD.
Here is what I did so far: 1) Turn off everything including AC cable out of wall 2) Used VSHD Loader1.1 to upload v107.peg file 3) It completed 100% then Erase and Program 4) After that its back to Boot Init Check H/w
Please help. THE SOLUTION ok for the benefit of everyone here is the scoop: Use VSHD edit and open a blank .cha file. Save it for MAXHD load it with loader/serial port and it should download - erase - program and Bingo. NO more boot loop!
VSDH edit can be downloaded from viewsat usa in the support/download section ="
