118.7 Channels missing
Username: Rustynail74
Post Number: 78
I scanned several times but not getting any H Polarity channels. I am receiving most of the V pol channels though. Could someone help me why that is the case? My LNB says Dp Pro on the back but the cable wire is connected to one LNB only. Dish Network guy installed the larger elliptical 33" dish. Any suggestions?
Username: Lomna
Post Number: 515
HARRIS... I strongly agree with you.
Anyways, It requires larger dish.
Username: Plymouth
Post Number: 7885
Haris
list your receiver.
Check the LNB Type and put it on OCS-DP or DP.
Post Number: 80
My receiver is VS Platinum. I tried using OCS-DP setting. No new channels. Thnx.
Username: Plymouth
Post Number: 7900
Haris
Unhook and rehook your cables, because it can be a bad connection and you will lose voltage for Horizontal TPs.
I hope you had try LNB Type standard
Username: Riconissan
Post Number: 237
Standard LNB type
and try scanning from a strong TP
