Username: Razz Post Number: 6 Registered: Feb-09
Saturday, February 28, 2009 - 15:36 GMT Still using 090227P and was working great untill I switched it off - I put reciever in place and reloaded it rolled it updated no prob (was on 119 when it rolled) now 110 is trying to roll its been like that for about 1/2hr, if I switch back to 119 it works great. 110 Getting 83% Signal 100% quality LNB - power on Type - Standard 22K - Off TP - 12223 Disec - correct
Username: Plymouth Canada
Post Number: 7840 Registered: Jan-08
Saturday, February 28, 2009 - 17:33 GMT Razzor Do a factory default and rescan your satellites with correct diseq port and don't forget to recheck your setting in antenna setup after each scan.
Username: Razz Post Number: 7 Registered: Feb-09
Saturday, February 28, 2009 - 17:34 GMT I meant VS2000 - I found that some channels do work on 110, so im assuming the ones that dont may be being moved to N3
Post Number: 7841 Registered: Jan-08
Saturday, February 28, 2009 - 17:36 GMT Razzor I have no comment that 110W lose channels.
Post Number: 7842 Registered: Jan-08
Saturday, February 28, 2009 - 17:44 GMT Razzor List your dish, is it a dish 500? If it is a dish LNB you put the LNB Type on OCS-DP, if not you use Standard, bad Type can result in lost of channels and autoroll.
Username: Viruscauser Leesburg,
Georgia
Post Number: 1002 Registered: Mar-07
Saturday, February 28, 2009 - 18:27 GMT Plymouth is right. A rescan should sort this problem out.
Username: Razz Post Number: 9 Registered: Feb-09
Saturday, February 28, 2009 - 18:29 GMT Not using Dish Pro, that setting is for Dish Pro only, been using standard or universal for the last three years
Post Number: 7852 Registered: Jan-08
Saturday, February 28, 2009 - 21:40 GMT Razzor You can try to put the autoroll off and put the keys manualy Here is the keys: Dish Network (0101) [Last update: Fri. Feb 27, 8:07 PM CST] 86: EE 81 EF BB D8 9F 8C 00 EE 06 35 E2 1C 1B 92 58 96: FE 4C 22 B6 AE F8 17 F6 68 69 FD 64 36 87 9E A8 New Dish Network New Provider ID (0106) [Last update: Thu. Aug 28, 4:14 PM CDT] 86: C9 DC DB 84 5A B8 2C DF 7F 32 8D E5 21 5C 45 4E 96: 4E B1 A8 DA 2D 92 90 D9 E6 3C 5E CE E4 FE E3 86 New
