Silver Member Username: Thakkar2000
Post Number: 212 Registered: Jun-06
Posted on hi guys....I can see dish network has added new channels...aka NDTV imagine- hindi channel....does it work for anyone? thanks |
Gold Member Username: Plymouth
Post Number: 7873 Registered: Jan-08
Posted on t23 NDTV Imagine is up on Echo 3 #574 Tp 12326 20000 H 5/6 v7714 a 7715 p7714
Post Number: 213 Registered: Jun-06
Posted on hi plymouth..thxs...so it works for u..y do i get scrambled channel:S help would be apprecaited!
Post Number: 7875 Registered: Jan-08
Posted on t23 Try it: put the auto Tp off then do a Tp scan on 12326
Post Number: 215 Registered: Jun-06
Posted on thx..it works! |
Post Number: 7882 Registered: Jan-08
Posted on t23 You are Wecome
