New member Username: RazzPost Number: 1 Registered: Feb-09 | I tried bin - I just get AR processing / loaded factory first, rebooted, etc.. etc.. ____________________________________ DBPSW-090227P ------------------------------------ * Versions - Release Date : 2009.02.27 - Main software : DBPSW-090227P - Bootloader : 0.0D * Change ( Main software upgrade ) - AR Update |
Silver Member Username: Tigger_woodsI AM BACK, MATCH PLAY FEB 25TH Post Number: 983 Registered: Jun-07 | Its no good, wait for new file. |
Gold Member Username: PlymouthCanada Post Number: 7817 Registered: Jan-08 | raz zor Check your setting in antenna setup, after a scan the setting can come with default setting. |
Silver Member Username: Tigger_woodsI AM BACK, MATCH PLAY FEB 25TH Post Number: 984 Registered: Jun-07 | VS Plat bin has been pulled from most sites. We are waiting on one. |
Silver Member Username: Tigger_woodsI AM BACK, MATCH PLAY FEB 25TH Post Number: 985 Registered: Jun-07 | The file was bad. Load the Cleaner file to fix it. Then just wait for a new file. C/P from Cyphris Quote: The VS Coders are aware of the - - - - issue and a new file is being made. It will be released when ready. |
New member Username: RazzPost Number: 2 Registered: Feb-09 | Plymoth - Ant settings are good - I also use a Pansat reciever and it worked fine up to yesterday on same LNB's (settings matched the previous setup and were checked)I get 92% signal 98% quality on both Tiger - Im new with VS what is a cleaner file? a factory bin? |
Silver Member Username: RiconissanPost Number: 199 Registered: Feb-09 | DBPSW-090227P Working since 12:30 eastern I am not experiencing any autoroll or freezing. J |
Silver Member Username: RiconissanPost Number: 200 Registered: Feb-09 | All 3 of my VS platinum are up with this bin downloaded from ftahq at 11:56 eastern. DBPSW-090227P |
New member Username: RazzPost Number: 3 Registered: Feb-09 | Thanks Rico ill try to load cleaner file as suggested by Tiger - I found this file : - Is this the one Tiger?? DBPSW-Cleaner-P ------------------------------------ * Versions - Release Date : 2008.12.09 |
Bronze Member Username: LagunaPost Number: 24 Registered: Apr-08 | Loaded xtrm bin and says "no CH" on receiver and it shows no tv channels. Is that what everyone else is experiencing or is mine dead? |
Gold Member Username: PlymouthCanada Post Number: 7823 Registered: Jan-08 | Vicente I give a answer on this thread: https://www.ecoustics.com/electronics/forum/home-video/554597.html |
New member Username: RazzPost Number: 4 Registered: Feb-09 | Well - it all seems to be working now, it took AR about 20min to roll, guess i was impatient earlier,(use to pansats) for now all is working Thanks for everyones help!!!! |
Silver Member Username: RiconissanPost Number: 204 Registered: Feb-09 | Thanks to Plymouth PhD |
Gold Member Username: PlymouthCanada Post Number: 7830 Registered: Jan-08 | LOL |
Bronze Member Username: LagunaPost Number: 26 Registered: Apr-08 | Plymouth, which factory bin and satellite info do I load from the viewsat usa website (i have viewsat extreme)? I know the loading the latest bin part. I went on that website and don't see anything pertinent. Thanks. |
Silver Member Username: RiconissanPost Number: 208 Registered: Feb-09 | Rico Suave Silver Member Username: Riconissan Post Number: 207 Registered: Feb-09 Posted on Friday, February 27, 2009 - 08:44 pm: Edit Post Viewsatusa. com Support Firmware VS Xtreme Factory Bin File - V0279 Sat info General Satellite Info File (Ultra ) Sat Info is the same for Xtreme |
New member Username: RazzPost Number: 5 Registered: Feb-09 | Vicente - Its under the firmware section follow this link |
