Puff 209# not downloadin
Username: Adrenalyzer
Post Number: 102
puff 209 does not download rite, u have puff night rider lights constantly across channel window
Username: Jkmago
Post Number: 286
Keep one hand on write and one hand on receiver switch,
once you see P hit write, it will download
It is working fine.
Cheers!
Post Number: 103
wat i mean, is download doesn't complete, when finished, the puff constantly flashes across, like night rider lights, and it never goes to on
Username: Jwl1
Post Number: 361
Adrenalizer--then I would suggest that you stop it at the end of the download. Meaning, don't let it get to that point, shut it off from the back. Plug in, scan, etc.
Username: Sccrskills
Post Number: 136
which loader should we use its been a while since i loaded a bin so i was wondering if i use blacklist updater v1.4 or ukronic's loader
Username: Jwl1
Post Number: 363
Sccrskills--you can use either.
Username: Psychmonster
Rhodium Member aint nuthin...
Post Number: 1003
jvvh full did not load...Fwank 209 did
Username: Nydas
Post Number: 14525
jvvh full is for use as a jtag file using jtag cable etc. This file is over 1 MB and easy to identify and even as the words "Full Jtag" in the file name.
Most people should use the standard BIN load using BL updater 1.4 and the released BIN which is under 500K.
Essential kit 103 for conversion to 103 LZMA boot Kit.
This is the new change recommended.
Convert to PUFF_LZMA. There will not be any more PUFF
PUFF_LZMA_209 BIN in separate file
Alternative PUFF_LZMA link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
