Need help on CW600P
Username: Plymouth
Post Number: 7773
Please if one know recover a satellite on this receiver(CW600P), I just have deleted the 119W and i'm not able to recover it.
If a file is needed please give me the link.
Thanks
Username: Nydas
Post Number: 14521
On 800s, I can add a new sat. Can't you add it on 600P?
Username: Plymouth
Post Number: 7775
Nalin
Yes but it not work, because i have a motorized dish on this receiver and i have lose all TPs.
On Viewsat i load the satellite info and all satellites and Tp come back.
Maybe Bruce 1 know where i can get this file.
Thanks
Username: Riconissan
Post Number: 169
I do not think there is a file.
You have to do it the old fashioned way?
Username: Dimwitt
Post Number: 1130
factory default - all
or load a channel list
Username: Plymouth
Post Number: 7777
Rico
When i had buy this receiver and load the bad file(600S) and Bruce 1 give me 2 files for recover my box, but i miss which one.
If i can't found this file, i will enter each TPs one by one.
Ho when i create a new one I'm not able to put 119 West, when i put west it come back with east.
Post Number: 175
searching for files.
I may have it in a backup disk somewhere.
this computer is clean since the hurricane.
I will let you know what I find.
Username: Plymouth
Post Number: 7778
Thanks Tooter
Check on this site and please give me which one i can load for recover my satellite.
http://mike.dynip.com/phcdl/category.php?id=14
Thanks
Post Number: 178
Nothing at that site
Post Number: 182
Sorry Plymouth. I do not have the file(s) you need.
What are you doing with a CW anyway?
Cash in some of those stock options and pick up a MaxHD.
Username: Plymouth
Post Number: 7781
Rico
This box is in my Bedroom and run with a motorized 18" dish, many time when the viewsat goes down this box still up.
Post Number: 186
I am Just joking with you.
I wish I could help. But it looks like you are going to have to find the position TP'S by running the motor. Takes some time.
I have started taking Digital pictures of my settings. I keep them on my phone that way if I am doing an install or mod I can save all of the LNB and TP and have te for ref. no matter what hardware.
Username: Plymouth
Post Number: 7784
Rico
I'm able to get the satellite but like I says if I create a new sat, I'm not able to put West on this satellite, it back on East.
I'm able to put all TPs, so it's only when I go to sleep that I use this Box, My Viewsat is much better for scan all satellites with my motorized 33" dish.
Post Number: 187
Got it.
Thanks for your help this week.
You are a good man.
J
Username: Plymouth
Post Number: 7785
Thanks you for your support to erase bad boy.
Username: Dimwitt
Post Number: 1131
cw600sp CXDatabaseV1.00.zip, is a channel list - use download data option on loader.
you will most likely have to rescan your sats, good idea to UPLOAD data after you complete your scans - all your data will be saved - if needed again.
Username: Boss_hog
Post Number: 65
The best I have ever seen.
Username: Plymouth
Post Number: 7802
Thanks Tooter
I would give a try later when bin out and come back with the result.
