Silver Member Username: Greatful, Post Number: 120 Registered: May-06 | i have no signal for 119 everything is fine for 110,everything was fine this morning i live in ohio so the switch was under ice and in water this morning this never happen before the wires look ok could the water or ice have caused this. thanks,greg |
Silver Member Username: Greatful, Post Number: 121 Registered: May-06 | i have a cw600p box |
Gold Member Username: PlymouthCanada Post Number: 7294 Registered: Jan-08 | Greg Try another port on switch and receiver. |
Silver Member Username: Greatful, Post Number: 122 Registered: May-06 | you think the switch could be bad will try that in the morning i know the dish is ok i have it marked and i would think that the lnb is ok too. thanks plymouth, greg |
Gold Member Username: PlymouthCanada Post Number: 7296 Registered: Jan-08 | Greg Yes if water penetrate inside, just to bad. |
New member Username: Bandino52Post Number: 2 Registered: May-08 | witch web is india vs sri lanka one day |
Bronze Member Username: Lubfr01Post Number: 84 Registered: Sep-07 | www.dishnet.com |
