Bronze Member Username: Ennio
Post Number: 57 Registered: Sep-07
Posted on How can you tell if is real or clone if you buy one? |
Gold Member Username: Plymouth
Post Number: 7308 Registered: Jan-08
Posted on ennio Look at captiveworks.com and check for dealer list.
Platinum Member Username: Nydas
Post Number: 14274 Registered: Jun-06
Posted on Buy from an authorised dealer. If you end up with a clone, however, there is a solution. CW700 Code Verification Crack (working on Original or Clone) If your serial is not working or not have the serial Use these Serial Numbers. 071112190 -> 071112199 071112200 -> 071112209 071112210 -> 071112219 071112220 -> 07111230 |
