Pansat 250 lastest bin
Username: Midas55
Bin file 510 which was release over night still has major problems. Seems to work OK on Echo 7 but does a major Freeze on echo 8. Remote locks up and you have to use the rocker arm. Anyone else having this problems?
Username: Audom
Vaughan maple, Ontario Canada
i have the same problem, my 250sm unable to use the remmote and front panel...help please?
Username: Nydas
Post Number: 13930
Load the 510 bin. At least your remote will start working. You will still get freezing.
Username: Audom
how can i down load bin 510 on 250sm ,if remote doesnt work?
Username: Audom
how to load 250sm with bin 510,if my remote and front panel dosnt work?
Username: Midas55
I took bin 510 off my STB. It is not worth loading. It freezes and you have to reboot the STB and it happens again. I'm waiting this one out. Coder will again come out with another bin.
Username: Dimwitt
Post Number: 1061
Audom david pen
Possibly with loader and null cable
connect receiver and computer with null cable, have receiver off at main power switch
start loader program, select latest bin or factory, start download, turn on receiver from main power
hopefully it loads and reboots to ON
Username: Midas55
Post Number: 7
Tooter is correct, but I got lucky and when EPG came up I cancelled it and pushed the menu button with the thumb drive already in the STB and I was able to switch bin files. I went back to 507. 510 I wouldn't recommend.
