NEED nfusion info, plzz respond
Username: Adrenalyzer
Post Number: 96
Hi, I would like to know how testers, bin loaders, load the bin on the nfusion solaris boxes, R232 cable? or S.D card? I'm tired of the R232 cable process, my compu dosen't have an 9 pin connection for the R232 cable, so i gotta take an old compu out of the closet, and re-hook up everything.
SO, I'M INTERESTED in a new box, that i can load bin without R232 cable, ANY SUGGESTIONS
Username: Nydas
Post Number: 13923
When you are talking about Nfusion, you are automatically talking about a good Broadband connection, and Ethernet downloads.
Username: Saqeeb9000
Post Number: 4470
first time u have to download by using RS32 cable,
if its not already with 1.30 bin,
then u don't need Rs32 after that,
its one time only,,
next time u can simply use remote to download bin,
press menu internet sw upgrade,its that simple,
or u can use webloader ,just hit ur ip adress using ur laptop/desktop comp,
and u wil get in to webloader and u can simply download from there without hastles of any wires...
by the bin's normally come after a month/2 month so ..
i know some people normally forget "how to download"...
last 3 bin's they put the bin in server ,
and if u simply turn off rec from back and turn it on again, it will say new bin availalbe (how simple is that)..
let me know if u need any help..
Post Number: 4471
did u already have a nfusion,
tell me which bin u have on ur nfusion..
Post Number: 97
i'm thinking about getting the nfusion solaris, i currently have an P.S 2500a
Wat would be the best box to get!! at a reasonable price??
Post Number: 4472
Nfusion solaris is cheap i think for $ 130 or so,
NF HD are expensive about $ 450-500,
some good /bad about nfusion,
firs good,
its 99% of the time up during ecm compare to other boxes,+ it's up with some bev channels while none of other boxes have this achievement yet..
bad,
channel change is slow, about 15-20 sec,
nova is more slower than solaris model..
pic quaily ain't that awesome,
u need a constant internet connection (network cable from router)..
with out internet it won't work..
its not built in pvr,
i mean it is but u can record it on comp directly and 95% people have problems using pvr...
2nd box is k1plus its new "kid" in town,
impressive picture
pvr (the next bin will be pvr ready)
option of using iks and standalone,
iks not that impressive,
standalone fixes are faster,
built in usb, plug and play,,
no bev channels with k1plus yet....
Username: Gregraf
Post Number: 1971
Good info Sada but my Nova only takes about 4 or 5 seconds to change channel. And my picture is as good as my Extreme.
Username: Gregraf
Post Number: 1972
Only problem with internet connection is my old lady b1tches about the cable going across living room floor. Haven't had time to drill two holes.
Post Number: 99
do you need an internet cable connection to the box, or can it be done wireless, with router, i have router on my desktop, for my laptop, so can a nfusion box be connected throu router, wireless?
And um, wat about extreme ultra? any good?? and how do they D.L bin on the dat box??
Username: Gregraf
Post Number: 1973
If you do a little reading you will see this stuff is already posted on this forum.
https://www.ecoustics.com/electronics/forum/home-video/543930.html
Post Number: 4473
andrenalizer,
let say ur router is close to ur tv, u can use network cable plug one end it ur nfusion rec and 2nd end to ur router,
lets say ur router is far away from nfusion rec,let say for upstair bedroom and u want nfusion rec there then u need to buy powerline adapter ( u can get it at any sat shop)..
powerline adapter u can plug one in ur router and the other end in any electrical outlet and u have high speed interent u can plug the network cable from ur adapter to nfusion rec (no messy wires etc)..
viewsat are good not the best ,
if u are looking for rec that needs least maintenance and u wanna watch channels all the time "nfusion is for you."
all other brands are same viewsat,sonicviwe all have same support,
nfusion is "little" advance,
